 Post Posted: Mon Jun 15, 2009 6:16 pm
The vega with a 7000rpm shift chip reaches max rpm of 7250 @ 2.82 seconds, it then falls to 5750 @ 3.30 and sits there before starting to climb again @ 3.96 amd crosses 1/8th @ 6500 6.3#
Does this look normal? :-k :-#
If not what are some possible problems?
 Post Posted: Mon Jun 15, 2009 6:21 pm
You put a logger in the Vega :-$ :-$
 Post Posted: Mon Jun 15, 2009 6:35 pm
No logger, this is played back by a mega 450 delay box.
Can't afford all the toy's =;
 Post Posted: Mon Jun 15, 2009 6:56 pm
That sounds about right to me?
 Post Posted: Mon Jun 15, 2009 8:20 pm
What are your Incrimentals? (sp)
Here is a pass from Saturday from mine...Spinning a little
60' 1.3534
330' 4.0461
594' 5.9281
660' 6.3548
MPH 105.45
3100' DA Green Track...
 Post Posted: Mon Jun 15, 2009 10:33 pm
sounds right to me also, depending on the converter I have in, it will sit there a lot longer after it shifts on mine.
David Lanning
IHRA NHRA 387B
http://www.nyesautomotive.net
Fleenor Racing Glides
"get one before one gets you"
 Post Posted: Tue Jun 16, 2009 5:30 am
Jody, my split times are within .01 of yours @ 60, 330 and 6.60
Thanks guy's
 Post Posted: Tue Jun 16, 2009 4:27 pm
My split times were almost identical also
60'-1.408
330-4.058
660'-6.310
mph-108.79
 Post Posted: Sat Jul 04, 2009 9:56 am
Sounds like your on the converter again at the shift. Not a Biggie IMO as long as it ETs.
What does this converter flash to?
