 Post Posted: Fri May 08, 2009 2:13 pm
I need to put a new two prong connector on the end of my adjustable RPM selector, prongs broke off. MSD wouldn't hook me up with a new end, want me to send it to the to repair for up to $30. Hell, after shipping it would damn near cost what a new one does. Anyone know where I can find a new end I can wire on that would fit the connection in the 2 step?
-Tanner
 Post Posted: Fri May 08, 2009 2:54 pm
Know if either of these fit the 2-step female ends?
http://www.radioshack.com/product/index ... Id=2103509
http://www.radioshack.com/product/index ... Id=2103498
http://www.mcmaster.com/#terminals/=1sdvqn
 Post Posted: Fri May 08, 2009 8:36 pm
If these are male pins that connect in where the RPM modules go then there should be something at Ratshack that would fit the holes. Just solder some pins on the wires and plug that puppy in since it's not something that you're continually connecting and disconnecting it shouldn't matter. Just put some heat shrink tubing on it with like 3/8 inch sticking out for the connection. ;-)
 Post Posted: Sat May 09, 2009 10:14 pm
Try these. I used to build adjustable 2 steps, used the pins out of these connectors.
http://www.radioshack.com/product/index ... Id=2103448
 Post Posted: Sun May 10, 2009 6:04 am
Tanner, Check a hobby store that sell radio controlled toys. They use connectors like the one Jmark posted...
 Post Posted: Sun May 10, 2009 9:44 am
Thanks all!
 Post Posted: Mon May 25, 2009 5:00 pm
X2 for the connectors that Mark suggested. I currently use these with the only issue being that when first installed they would occasionally fall out. Since then I daub a little solder on them and pinch them slightly so they fit snug.
Greg
