 Post subject: CSR Water Pump
 Post Posted: Sat Jan 03, 2009 10:43 pm
Has anybody put new brushes in there CSR water Pump? How did you get the four brushes back in.. I had to take the cap off  to put the wire back on the spade and now it looks like it going to be a bear trying to hold all four brushes to get the cap back on..... :-k
If you don't have the best of everything, make the best of everything you have.
 Post Posted: Sat Jan 03, 2009 10:53 pm
Have fun  ;-) , I had to solder a wire back on in mine and yes they are a bugger to do.Look where the brushes slide in , there might be small holes where ya can put in a small piece of wire to hold them down like alt. brushes. Cant quit remember though.
523ci Brodix 1803 Big Dukes. 1108 HP @ 7700rpm cast intake,single 4 on gas. Heads done by CBOGGS/RaceFlowDevelopment
 Post Posted: Sun Jan 04, 2009 8:47 am
Like Brian said there is a small hole to slide in after you get one brush in the brush holder...
 Post Posted: Sun Jan 04, 2009 9:05 am
Thanks guys I will check it out Monday when I make it over to the shop.. =D>
 Post Posted: Sun Feb 15, 2009 8:11 pm
I just put a seal in mine this weekend!
They ought to send directions!
Here's how you do it:
Look at the brush holder.  Near the end of it there is a hole in each side.  Press the brush in with your finger and then press it a little farther in with a screwdriver.  Take a very small wire and insert it through both holes.  It will hold the brush back.  Use a wire that is about 5-6" long.  Leave it hanging out the side.  Do this for all the brushes.  Next put the motor partially back together (within about 1/16" to 1/8").  Now pull all the wires out and it will slide together the rest of the way.
I used strands of copper out of an AWG 14 wire.  These are small, flexible, and easily fit through the holes.
I hope this information helps.  Once you do it once it's really easy.
I'd put a new seal in while you're in there!
Good luck!
Matt
2011 Atlanta Dragway King of the Track
 Post Posted: Sun Feb 15, 2009 8:48 pm
Exactly like Matt described except I used torch tip cleaners. \:D/
