need help figuring out a plug
http://motorsportsvillage.com/forum/viewtopic.php?f=7&t=4765
Author:  monsooni [ Thu Sep 04, 2008 3:19 pm ]
Post subject:  need help figuring out a plug
I am trying to come up with a plug to use in my car   right now it has a 9 heat rating and they look like there fouled out by fuel, I had trouble with my car  when i ran it down the track  after shifting into high gear it  acted up like it was loaded up or not enough fuel, anyways i pulled these plugs and they are wet and black way up the threads even, I was told to run a hotter plug do you guys think this will help if so what plug   thx to all
Author:  Elkyman [ Thu Sep 04, 2008 3:47 pm ]
Post subject:  need more info
What kind of heads do you run, type of fuel used, and compresion????
Most of the cyl head manuf. will know what works best with your fuel & compression.
Carb, or injection?
Author:  monsooni [ Thu Sep 04, 2008 5:07 pm ]
pump gas, 10.5 to 1 compression   aluminum afr 195 heads   thx
Author:  Scott Smith [ Thu Sep 04, 2008 5:20 pm ]
need to be looking at the carb not the plugs.  ;-)
Author:  monsooni [ Fri Sep 05, 2008 7:25 am ]
what part of the carb, carb does seem fat  but i dont know how to tune a carb  thx  it is a quick fuel 750 race carb
