 Post Posted: Thu Sep 04, 2008 3:19 pm
I am trying to come up with a plug to use in my car   right now it has a 9 heat rating and they look like there fouled out by fuel, I had trouble with my car  when i ran it down the track  after shifting into high gear it  acted up like it was loaded up or not enough fuel, anyways i pulled these plugs and they are wet and black way up the threads even, I was told to run a hotter plug do you guys think this will help if so what plug   thx to all
 Post subject: need more info
 Post Posted: Thu Sep 04, 2008 3:47 pm
What kind of heads do you run, type of fuel used, and compresion????
Most of the cyl head manuf. will know what works best with your fuel & compression.
Carb, or injection?
 Post Posted: Thu Sep 04, 2008 5:07 pm
pump gas, 10.5 to 1 compression   aluminum afr 195 heads   thx
 Post Posted: Thu Sep 04, 2008 5:20 pm
need to be looking at the carb not the plugs.  ;-)
 Post Posted: Fri Sep 05, 2008 7:25 am
what part of the carb, carb does seem fat  but i dont know how to tune a carb  thx  it is a quick fuel 750 race carb
