 Post subject: Alt Bracket
 Post Posted: Tue May 20, 2008 9:34 pm
Has anybody used or seen this bracket on a Dragster? Does it clear the frame rails and motor plate?
If you don't have the best of everything, make the best of everything you have.
 Post Posted: Wed May 21, 2008 5:28 am
Don't know about that one but this home made one is a good fit for both a door car and a digger.  I've run mounts like this on the last three cars I've owned with zero problems.
http://motorsportsvillage.com/forum/vie ... or+bracket
 Post Posted: Wed May 21, 2008 1:08 pm
Ken I wish I could used one of those. My fuel pump is in that spot and the crank trigger is on the other side ... #-o   :-k
 Post Posted: Wed May 21, 2008 1:16 pm
Crank trigger and belt drive pump were on the other side on this engine and on all the rest I've ever had also.  You could move the pump!  =;
 Post Posted: Wed May 21, 2008 1:26 pm
I will see what I can do  :-k
