 Post subject: TWO Step.
 Post Posted: Tue May 13, 2008 7:06 am
When the 2 step is engaged and the motor is stumbleing does it put wear on the valve springs or cause damage to the motor?
 Post Posted: Tue May 13, 2008 7:37 am
My engine guy says they are hard on rotating assemblies and I didn't use one for a long time because of that.  The new Digital 7 box I got now isn't suppose to be as hard on'em according to what I've read and I do use it now.
 Post subject: KRAZYKEN
 Post Posted: Tue May 13, 2008 12:05 pm
I have ran a 3 step on my 55 for years and never had a problem.
 Post Posted: Tue May 13, 2008 1:24 pm
I've run a 2 step for as long as I can remember without any problems.  My routine is to stage up and when the first bulb lights I put it on the floor and release the button for the delay box. When I'm crossing over and there is a slow car in the other lane that will leave it on the rev limiter for a few seconds.
 Post Posted: Tue May 20, 2008 11:59 am
I use to run a three step well i still do but it never works because i run the launch control on my car now but never had a problem with it .
It seems like it would kinda take some toll when you are setting there and it's banging away .
I know my car is way more consistent with the launch control plus you never heat up the convertor just sits at idle .
 Post Posted: Wed May 28, 2008 9:48 am
anybody know how I can test a 2 step, basically the lower rpm limit wasn't kicking in, the upper rpm limit was fine, tested all other circuits which were fine so I figure the 2 step it dead. If I put 12v across it, how and what would I measure at the chip terminals ? Is it resistance ?
 Post Posted: Wed May 28, 2008 10:17 am
A 2-step is nothing more than a relay. It should have NO resistance across the low chip terminals when energized, NO resistance across the hi chip terminals when it is not energized. I used to make mine with potentiometers to adjust the low side where I wanted.
I used to have a chart of resistance in 1000 RPM steps, and it was not a linear change. I would have to do some digging, I have had digital boxes for about 5 years now. If you measure some known good ones you can get an idea. You can even make your own.
 Post Posted: Wed May 28, 2008 3:42 pm
just put a 3k chip in it, fire it up and wow down on the loud pedal, if it goes above 3,000 rpm it's not working. If you think the chip's bad I think there is a resistance test you can do and I'm pretty sure someone here has the values.
 Post Posted: Wed May 28, 2008 3:54 pm
Here's what a digital 7 sounds like at 4800 and autostart.
The pedal is on the floor the whole time.
http://bumracing.com/video/mmp10-29-05-3.wmv
 Post Posted: Thu May 29, 2008 3:38 am
one moduel works the other doesn't, I put a 3K chip in the RPM limit slot and it was fine, but in the other module it does nothing....time to replace it I think.
 Post Posted: Mon Jun 02, 2008 4:02 am
Link to chart of resistance for MSD chips posted previously on MSV.
http://motorsportsvillage.com/forum/vie ... resistance
Greg
