 Post subject: K&R PRO-CUBE
 Post Posted: Mon Jan 21, 2008 8:01 pm
Does any body here use the K&R pro-cube. If so I have a question on the cross-over part.. Thanks kenny ](*,)
 Post Posted: Mon Jan 21, 2008 11:48 pm
Yes.
 Post Posted: Tue Jan 22, 2008 6:38 am
yep.
what's the question?
 Post Posted: Tue Jan 22, 2008 8:36 am
I run 1 too. Here's the manual.
http://www.krperformance.com/pdf/CubeIIwithBump-up1.pdf
 Post subject: krazy55ken
 Post Posted: Tue Jan 22, 2008 5:26 pm
I have had mine for 2 years now but never used the cros-over. I was just wanted to know when you cross over do you put the same delay on that side to or not. thanks kenny
 Post Posted: Tue Jan 22, 2008 6:16 pm
Sounds like someone's local track is going to cross talk system this year!  Welcome to the "new" bracket racing.
Most guys that cross over either add a number or take one out, depending on who you talk to.  I guess that is something that you need to sort out in the first race or two.  If you can get the track owner to setup the tree on a few handicap starts at a test and tune you could find out before you go racing.
 Post Posted: Tue Jan 22, 2008 7:55 pm
Thats not a ploblem with our home trace I am the one that usually runs the lights on our wednesday test and tunes.
 Post Posted: Tue Jan 22, 2008 9:06 pm
Your dial in the left. Opp's dial in the right. Let go of the button on the first flash and drive the stripe.  :-$
 Post Posted: Tue Jan 22, 2008 9:10 pm
if your good in math, you can crossover without a c/o box, if that makes any sense to you. say you dialed 10.00 and i dialed 9.00 and i run 1.000 in my box for delay. i would just change my delay to 2.000 and let go off your side!
 Post Posted: Tue Jan 22, 2008 9:38 pm
Not at our track we had blinders up.....
 Post Posted: Tue Jan 22, 2008 9:45 pm
Remember them days Ken?  ;-)
I had a calculator taped to the dash before cross overs were invented.
The other racers would get so pissed that would lie about their Dial to me. :D
 Post Posted: Wed Jan 23, 2008 6:20 am
Did that also \:D/  with my 1st Denbear box...Kept the cal in my jacket pocket =;  =; Teck guy use to say to me "don't forget your calculator" \:D/  \:D/  \:D/
 Post Posted: Wed Jan 23, 2008 4:21 pm
i have been known to forget the calculator and did the math with shoe polish right there on the ground of the staging lanes.... boy does that get people's attention!
