 Post subject: what ign to use?
 Post Posted: Tue May 23, 2006 2:56 pm
i'm building a 540-blown-inj-alky bbc.it has 9.6 to 1 comp[right now but thinking of angle milling heads to bring up higher.was told needed more comp for alky eng]brodix 2 plus heads.like to see 1100hp from engine so need to know what ign system would be for me to use on this engine combo.
 Post Posted: Tue May 23, 2006 3:04 pm
i would suggest a msd or mabey a crane fireball.
 Post Posted: Tue May 23, 2006 3:05 pm
Since you're spending that much money to start with I'd have to go with the MSD Digital 7 with the boost reference timing control. Those things are adjustable for each individual cylinder if needed and can be programmed from a laptop computer or via a hand held programmer.
It's funny. Here I am telling you to run one and I have that entire setup sitting on the work bench and don't have it in the car? O:) Hummmm, what's wrong with this picture? =;
Site Admins ain't nobody's hero!
 Post Posted: Tue May 23, 2006 7:37 pm
I bet it looks cool sittin on the bench O:) =D> Barry
 Post Posted: Tue May 23, 2006 7:40 pm
I would go with the digital 7 also on a blower motor.
Are'nt the 2 plus heads small for a blower? :-k
 Post Posted: Tue May 23, 2006 9:55 pm
i don't know about heads.first blower engine for me and already had these heads.i was thinking about asking on here if i should have my heads flowed[ported] or not.right now i'm just buying up parts for the engine.
 Post Posted: Wed May 24, 2006 6:26 am
you should see the chips fly when he fires it up! =D>
 Post Posted: Tue Nov 07, 2006 3:10 pm
surely blown alky the best way to go is with a mag, super mag 3 would do the trick just fine
 Post Posted: Tue Nov 07, 2006 4:09 pm
i picked up a new msd digital-6 plus box and a msd crank trigger dist. on a trade.would these work or should i sell these and go to something else?
 Post Posted: Tue Nov 07, 2006 4:36 pm
lol @ digital bench...
I could do you a deal on a new set of 11.5 :1 je forged (coated) bought for a 540 blower motor, (is there 10 in that box duane ?)
Sam
 Post Posted: Tue Nov 07, 2006 5:27 pm
sam...PM me.
don
 Post Posted: Tue Nov 07, 2006 7:09 pm
Is there a way to do a boost referenced retard on that thing? I know my Digital 7 has one built in but I'm not familiar with the 6 box.
I'm also not familiar with a blower engine either but from what I've seen/read they (boost retards) are used a lot and I'd say it's probably needed even more if you're going to street drive this thing. I do know that you can't run a crank trigger on the street and expect to keep bearings in the engine! Been there, done that on my SBC! A timing retard may take care of this problem though.
On my SBC I finally put a throttle activated switch that changed the ignition timing from the distributor to the crank trigger when it went WFO. Anything under WFO then it ran on the distributor. After I put that setup on the engine it did fine, even on the street but before that it would beat a set of main bearings out in about 100 miles. Please note also that this engine was only around 10.5 to 1 compression and 34* timing!
I saw another post that suggested a Magneto. If there is variable timing in that thing it might work also but I'm not familar with one and have no opinion one way or the other. I'll leave that to someone that knows what they are talking about.
NEXT
 Post Posted: Tue Nov 07, 2006 8:53 pm
I'm going to recomend a magneto also .. with alky, especially if over driven ....
 Post Posted: Tue Nov 07, 2006 8:59 pm
There is a blown BBC in a camaro at my home track. He runs the MSD 10 plus......I do beleve it in the 540 range and it runs 7.60s at 180 in the quarter. Something to watch on the starting line. Barry =;
 Post Posted: Tue Nov 07, 2006 11:58 pm
so we are saying i need to get rid of the crank trigger for sure then and the msd digital-6 plus box?or trade them for a mag..i will be driving some on the street.
