 Post Posted: Fri Feb 01, 2008 1:22 pm
I know you called him......What did he say?????
 Post Posted: Fri Feb 01, 2008 4:29 pm
Barry I've only traded Email messages with him at this point.  I sent him some pointed questions around lunch time when I found out they were short.
Greg Kelly says he has the extension wire if I want to keep them and extend them.  I'll wait and see what they want to do about it first though.
DAMNIT!  Not a good day! O:)
 Post Posted: Fri Feb 01, 2008 4:34 pm
You could put connectors on each one O:) ...Oh yea there's 8 more you will have to get from........somewhere and more $$$$$$$$$ =;  =;
I checked how much $ I spent on those connectors (even tho I really didn't want to) had a total of $98 bucks and have a few pins left over  O:)
 Post Posted: Fri Feb 01, 2008 4:47 pm
These have stake on terminals with screws on'em, the same as the one on my Dodge has.  I've got some TC wire but I don't think I have enough.  I'll have to measure it and see if I can make it work while I wait on an answer from them.  If I mount the TC-4s on the firewall they will probably work.  Didn't want to do that though.
 Post Posted: Thu Feb 07, 2008 11:25 pm
Well, the people I got the thermocouples from gave me free 2 day shipping on the thermocouple extensions for those short ones.  And BTW, these have the exposed tips for fast reading and also they have a lifetime warranty!  So the additional extension cables will cost me another $15.
Unlike the wire connectors, this one worked out OK in the end. ;-)
 Post Posted: Fri Feb 08, 2008 7:16 am
Where did you mount the TC-4s?
 Post Posted: Fri Feb 08, 2008 9:43 am
Scott they are mounted on the transmission tunnel just under the dash.  Extensions of 3 ft or less will work for 1, 2, and the rest will be much shorter than that.  I also have some K wire here left over from the one I installed on my Dodge several years ago.
They should be here today so I'll likely have all the stuff in there by days end.
 Post Posted: Fri Feb 08, 2008 12:24 pm
Greg is sending me 2 new LC-1s that should be here today as well. Plus my new drive shaft pickup for my new Strange Ultra Case.
It takes a different pickup because the pinion yoke is sunk into the pinion support.
You can see what I'm taking about here.
http://www.strangeengineering.net/catalog/049.html
 Post Posted: Fri Feb 08, 2008 12:39 pm
So have they crapped out or what?  O:)  They're not even a year old yet?  O:) Donee hasn't had any problems with his that I'm aware of?
Scott Smith wrote:
Plus my new drive shaft pickup for my new Strange Ultra Case.  It takes a different pickup because the pinion yoke is sunk into the pinion support.
Someone HAD some money!
 Post Posted: Fri Feb 08, 2008 3:15 pm
There was a bad batch that got out. Mine were bad from the start.
My originals were fine until the drive shaft took them out when it left the building like Elvis.  O:)
