 Post subject: Data Loggers?
 Post Posted: Tue Dec 18, 2007 11:07 am
I'm looking into buying one of these and at this point it's narrowed down to either an Innovate or Computech.  Slowpoke has an Innovate and his only issue has been that it's not "user friendly", ie, he had to send it back to them once because he couldn't get some of the addon stuff to work.  He hasn't had a problem with it since and says he would buy one again even with the issues he has had.
I know Barry, Sam and Chuck have bought the Computech logger but they now offer a cheaper model that is modular, like the Innovate but much more expensive and I don't know whether I want to buy one that none of us has tried before.  Other than sample rate there isn't much of an advantage with the Computech modular logger.
I think Scott has an Innovate logger so maybe he will chime in and give an opinion as well.
So is there anyone else out there with experience on one of these with an opinion one way or the other?
 Post Posted: Tue Dec 18, 2007 12:01 pm
I really like mine and with the help I got from Chuck it made it easy to use and really the soft ware is very user friendly  =; ...Every thing is loaded and if you get another sensor all you need to do is turn it on..
With the newer unit you just pull the memory card out and plug it in your lab top and down load your run...
With the one that I have you need to remove the display unit and plug that into your lab top to down load your run...
It was for me and I think everyone here knows how good I am with computers and software [-o<  [-o<  [-o<  =;
Get it Ken......You will open up a whole new world of questions =;  =;
 Post Posted: Tue Dec 18, 2007 12:11 pm
And places to spend money
 Post Posted: Tue Dec 18, 2007 12:30 pm
Ken here is another data logger you may have some interest in, I have talked to Randy McMahon about one,but I have, not bought one yet,they are pretty decent and user friendly.JMHO
http://www.rpmperf.com/
 Post Posted: Tue Dec 18, 2007 3:54 pm
Ken, I'd recommend a Pi system, but thats very very expensive, so I guess we are down to computech etc.. I'd recommend the computech as there are at least 3 other users on the forum.  Or unless they guy round the corner has a different make that he likes..
they all have there plus points and also the bad points. with your computer experience you should not have too many problems..
Sam
 Post Posted: Tue Dec 18, 2007 4:03 pm
With the Computech..... Chucks a phone call away =;  We even talked when he was racin \:D/  \:D/
 Post Posted: Wed Dec 19, 2007 4:52 am
hi Ken
have you had a look at the Racepak stuff
its a little on the exxxy side but from what i have found they are a great logger & easy to use
regards
rod
 Post Posted: Wed Dec 19, 2007 6:15 am
Obviously my pockets aren't deep enough to afford the expensive stuff.  If I had plenty of money I'd still be in a dragster and running 4.90s.
I set myself a limit on this and even the modular Computech deal is slightly beyond that, which makes the Innovate setup even more appealing.  I guess some data is better than no data.
I think what I ultimately want is engine and driveshaft RPM, 8 EGTs, at least one O2, Fuel pressure, G acceleration, voltage and maybe a temp or two.
Dunno, looks like this isn't going to happen until after the first of the year anyway so I've got some time to think about what I want and do some shopping around as well.
 Post Posted: Wed Dec 19, 2007 7:06 pm
Innovate is a "do it yourself" system that you can add sensors as you want.
If you can run wires and solder  I would go with Innovate. It's very powerful and it's no secret their o2 is the best on the market bar none.
Race Pac is outrageously expensive and propertary.
Innovate can use any 0-5v sensor whether it's a GM water temp sensor or a Ford TPS.
Here's some pics of what I did.
Shock sensor construction.
Fuel Pressure
Oil Pressure
Drive shaft
Put everything in an Aluminum Box.
Log
o2 sensor
 Post Posted: Wed Dec 19, 2007 7:23 pm
Scott, do you run gas or alky??
 Post Posted: Wed Dec 19, 2007 7:28 pm
both
 Post Posted: Wed Dec 19, 2007 7:50 pm
How long do those 02s last running on gas???
 Post Posted: Wed Dec 19, 2007 8:07 pm
They last about 40 hours.
I got them down to 38 bucks from CarQuest.
 Post Posted: Wed Dec 19, 2007 8:13 pm
40 hours of running on a drag car is a lot considering how much actual run time is involved.  I've never run a hobbs meter on one but I'll bet that would take me thru most of a season and since I don't plan to run gas all year, I might be able to get two or three seasons out of one.  Hummm, interesting.
The Wego II I use that belongs to a friend states in their literature that they only go about 15 hours before they go south.  From what I understand though, the Innovate system will compensate for degredation of the sensor and correct the calibration when needed.
 Post Posted: Wed Dec 19, 2007 8:15 pm
Scott, are those pressure transducers you have from Innovate or did you find an aftermarket source for them?  If they are aftermarket, what did they come on originally?
Also, what did you use for the Hall effect pickup on the rear end yoke?  Is it aftermarket also and if so, where did you get it and how many magnets did you use.
