 Post Posted: Wed Nov 14, 2007 11:05 pm
nlmsc33 wrote:
anyhoo it also has 2 buttons on the steering wheel.
the big red one is for the transbrake.
what in the WORLD could that other button be for???
if it was a tap button.... where should it be wired to???
ps. the line-loc is on the shifter so that's not it.
Probably a "bump down" button for the K&R delay box. It is wired to an input on the box specifically for that.
I never used one. I never liked the idea of getting more than one chance to red-light. I guess I haven't been able to tell I was late soon enough to do anything about it.
IT's probably a tap up or tap down feature.  As far as where it's wired it depends on the box but if you have the manual it should discuss that.  It basically is a programable feature that adds or subtracts a programmed amount of time from or to your delay time.  If you think you were late on the tree and you have the other button setup as a tap down you can tickle the other button and take off some time.  How much depends on how you programmed it.
George
 Post Posted: Wed Nov 14, 2007 11:07 pm
The Tap button may be for the new design delay box so if you think you cut a bad light you can cut a pre-programmed amount of time from your reaction time. A freind has his set to .010 so if he thinks he cut a fairly bad one he will hit it a time or two and has won rounds this way..
 Post Posted: Wed Nov 14, 2007 11:08 pm
Could be a three step button!  That last digger I had had one on the steering wheel.
 Post Posted: Wed Nov 14, 2007 11:27 pm
Mel what's the model of the box?
George
 Post Posted: Wed Nov 14, 2007 11:59 pm
Ok Here's the link to that manual.
http://www.krperformance.com/pdf/XTC-200.pdf
If it's wired to the "sub" terminal it's being used as a bump down.
George
 Post Posted: Thu Nov 15, 2007 12:07 am
And all you foot brakers think we just sit there with a finger on a button. =;  =;  =;
George
 Post Posted: Thu Nov 15, 2007 8:03 am
Box class is easy.....all you do is turn the button loose and the car does everything else :-  #-o  :-k  =;
 Post Posted: Thu Nov 15, 2007 12:08 pm
I know how you feel Mel.
3 on steering (transbrake, burnout limiter, line lock)
I've got my logger set on manual as well ( missed setting it more runs than not.
since I moved the mastercylinder I've managed to hit the fuel pump switch several times and turn it off.
I see a major rewire job coming up... mind you it needs it, I've only ever seen the tacho once on a run... its way down low.. roll on the new shop..
Sam
