 Post subject: Dragster Dash Panel
 Post Posted: Thu Nov 08, 2007 5:54 pm
It seems that I have a limited amount of space for gauges in my dash panel. I can only fit four 2 1/16" gauges and a 2 5/8" tach in there.
I know I need a oil pressure, water temp, trans temp, but the last gauge is a toss up, either fuel pressure or battery voltage.
Suggestions? :-
 Post Posted: Thu Nov 08, 2007 6:12 pm
are you going to get a data logger??
 Post Posted: Thu Nov 08, 2007 7:00 pm
Hopefully, at some time I will get one. But, not at first.
 Post Posted: Thu Nov 08, 2007 7:11 pm
This is what Barry's hinting at when he asked about a logger.
http://www.computechracing.com/Product_Guide/dataacquisition.html
If you're going to use a logger anyway you can use this set up with the display unit. If you haven't already bought gauges this will be less expensive than buying both. I'm a dealer for them so PM me if yo want me to get you a quote.
 Post Posted: Fri Nov 09, 2007 9:27 am
I'd say voltage if your running a total loss system, doubt you'll see fuel pressure actually on a run anyway, plus you can mount a gauge on a fitting on the motor which your crew can check before a run.
