Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4
 Post Posted: Thu Oct 18, 2007 2:51 pm
IT IS FIXED!!!
did you put the second battery in as well???
 Post Posted: Thu Oct 18, 2007 3:37 pm
NO, NO OTHER CHANGES!!  AND I EVEN RECONNECTED MY ALTERNATOR DROP OUT SWITCH ON THE CARB!!
 Post Posted: Thu Oct 18, 2007 3:43 pm
When you have a few minutes, oh ya you're retired, would you post a pic of that alternator drop out switch.  Thanks
 Post Posted: Thu Oct 18, 2007 4:36 pm
Ken, Just leave the alt hooked up, it won't do anything to vary your et...
 Post Posted: Thu Oct 18, 2007 7:11 pm
This is the one I use on the Dominator setup.  It won't work on your dual carb setup cuz I make the switch with the Dominator linkage.
This is the one I use with the dual carb setup using Enderle linkage.  I use one of the set collars that holds the linkage in place with a longer allen screw to work the switch.
I also have a bank of those type switches under the dash on the throttle on the Studebaker that I use for the alternator drop out, to only allow the N2O system activate at WOT and another one that switched the ignition from the distributor to the crank trigger pickup.  I also have two of those switches mounted on the transmission.  One on the shifter arm and another on the transbrake solenoid.  I used those for different stages of activation, ie, low gear only, high gear only or at the release of the Tbrake.  Yeah, just love them gizzmos!  =;
