 Post subject: start retard
 Post Posted: Sun Apr 29, 2007 1:42 am
have you noticed there is no end to my questions? My digital 6 msd has a 20 degree retard for easier starting. I unhooked it- the car idles much better and still starts fine (36 total advance) so whats the point of the retard? thanks in advance, Ty
 Post subject: Re: start retard
 Post Posted: Sun Apr 29, 2007 8:04 am
Is your distributor locked out at 36 or are you running a crank trigger?
The reason it probably idles better is because the start retard stays in until the engine gets to a certian RPM after it starts. I've heard 800 and also 1200 RPM to deactivate that retard so that probably explains that.
As far as the retards go, I've heard ppl sware by them and others swear at them! Some engines just don't like'em whereas others do.
All I can say is if there aren't any problems without it then don't use it!
 Post Posted: Sun Apr 29, 2007 4:47 pm
With the MSD depending how you wire it you will get a retard only when cranking or if you wire it via the box it will stay retarded until it goes over 1300 rpm.
in your case (if you want the retard) run the activation wire from the solenoid feed wire, that way as soon as you stop cranking (engine run condition) it will have full spark.
Sam
 Post Posted: Sun Apr 29, 2007 5:15 pm
Mine only retards during crank...When you release the starter it's back to normal =;
 Post Posted: Sun Apr 29, 2007 6:27 pm
I don't use one at all, even with the crank trigger. =;
 Post Posted: Sun Apr 29, 2007 6:59 pm
That's cause you have a Tiny block =; =;
 Post Posted: Sun Apr 29, 2007 8:23 pm
=; =; =; =; \:D/ \:D/ \:D/
 Post Posted: Mon Apr 30, 2007 12:34 am
I have 2 of them hanging on the wall in the shop. I also have a few flexplates with teeth missing. I quit using them and no more kick backs.
 Post Posted: Mon Apr 30, 2007 9:34 am
I have two retards on my car. One wired in the box and one behind the steering wheel. [-(
 Post Posted: Mon Apr 30, 2007 1:57 pm
I spot welded the distributer advance. thanks for the great info everyone. its wierd not having to figure out stuff by yourself anymore. (thanks to a good forum) Ty
 Post Posted: Mon Apr 30, 2007 3:45 pm
thats what i did a LONG time ago. no issues for me but i use a tilton mini starter and 2 batteries. timing is set at 36*.
