 Post subject: Att;;;; Chuck and Barry
 Post Posted: Mon Apr 23, 2007 2:42 pm
could you guys make use of a manifold pressure sensor ?
I've found a nice small unit that will go to at least 25 in/HG depression and also the same the other way
I can send you one if you think you have a need, I've tested it today and can send you the curve (straight line) for volts out to manifold depression.
5 volts in and and at atmospheric its about 2.4 volts output drops with more manifold depression.
Easy to fit, just needs a 1/4 (6mm) hole drilling for the sensor it seals on an O ring, fit to a flat surface and a second threaded hole to retain it (with a small screw / bolt) a few mm away. and it's very light.
let me know if they are any good to you and I'll send some, let me know how long the leads need to be and I'll make a lead long enough to reach the logger with the correct plug on the wire.
Sam
 Post Posted: Mon Apr 23, 2007 3:09 pm
Sam, you know if I had one I would use it, with a race car there's no such thing as TMI. I think it would useful in determining engine load although I don't know what I would do with that knowledge at this point. As far as lead length goes probably a couple of feet would be plenty for me. I put weather pak connectors on everything anyway.
 Post Posted: Mon Apr 23, 2007 3:57 pm
Ok chuck,
give me a few days and I'll pop one in the post..
did you get the others yet ?
Sam
 Post Posted: Mon Apr 23, 2007 4:00 pm
Sure Sam Im with Chuck on this one =; ....Thanks \:D/
 Post Posted: Mon Apr 23, 2007 4:14 pm
Sam wrote:
Ok chuck,
Not yet. I'll let you know when they get here. If you want to send one to me for Barry, I'll send it to him from here. Thanks.
 Post Posted: Mon Apr 23, 2007 4:24 pm
gearhead1011 wrote:
Sam wrote:
Ok chuck,
Im thinking that Sam should send it to me and I'll send it to you Chuck as your mail man walks real slow =; =; =;
 Post Posted: Mon Apr 23, 2007 4:36 pm
gearhead1011 wrote:
Sam wrote:
Ok chuck,
I don't think what my mail man does even qualifies as a slow walk #-o
 Post Posted: Tue Apr 24, 2007 5:46 am
nlmsc33 wrote:
now that's funny right there. =;
i'd have to agree though.
how much info helps you win races??
how much before it gets in the way??
i dunno anything compared to some of you guys & me go LOTS of rounds all the time.
maybe ignorance IS bliss \:D/
now thats really funny mel....is that car done yet??????Nooooooooooo =;
 Post Posted: Thu Apr 26, 2007 1:36 pm
gearhead1011 wrote:
Sam wrote:
Ok chuck,
I got the 1st package today although to be fair to my mailman I hadn't checked tha mail for a few, days. Thanks Sam.
