 Post Posted: Fri Jan 19, 2007 6:55 pm
I like relalys as It takes all the load off the switch... So you don't need a 14 size wire from the switch....I would use a relay for the fuel pump and put it as close to the pump as possible and make sure you fuse the power wire to the relay..... =;[/quote]
I said that in my other post O:)
 Post Posted: Fri Jan 19, 2007 7:17 pm
I like relays, modern ones are very reliable and as someone said buy decent ones and you wont have problems.
I think I mentioned on a post maybe on RJ yonks ago, put a LED on the output of the relay, it may not fix the fault you have but it will eliminate the wiring and switch up to the point that you have voltage at the component side of the relay.
most modern relays only need something like a 125 milleamp supply so if you put the relay close to your pump etc you can use a 26 awg to switch the relay.
if you are bothered about weight use raychem cables, probably wont last as long as some of the other stuff available but has good current carrying capacity (20awg = 7 amps if memory serves me right) and has very thin insulation. insulation does tend to crack in time, depends how much you are bothered about weight.
Sam
 Post Posted: Fri Jan 19, 2007 7:20 pm
Yes, I think you did but you didn't answer my question. Do you fuse the circuit that activates that relay?
Poor Mark. Here he was just wanting some straight answers and now I'll bet his head is spinning from information overload! =;
 Post Posted: Fri Jan 19, 2007 7:43 pm
The arc switch box is fused and I also fused the power wire to the relay =; I really suck at explaining stuff don't I [-( [-(
