 Post subject: Trans brake
 Post Posted: Fri Dec 29, 2006 12:01 am
Does a trans brake need a relay? Mine only seems to occasionally want to work. I thought maybe it was a loose wire, but then a buddy thought maybe it needed a lot more juice than I was giving it...or consistent juice.
thanks
Best 1/4 mile time (dead hook) = 31.32 @ 28mph!!!  (I'm in better shape now!)
 Post Posted: Fri Dec 29, 2006 12:55 am
Never seen one hooked up with a relay. Might just want to check your connections and make sure they are clean. Also, take an ohmmeter and check your switch and make sure you're getting continuity at every click of the switch. I have seen switches fail like this.
George
 Post Posted: Fri Dec 29, 2006 10:29 am
Yea What he said. No Relay would cause a delay and make your reaction time go in the toilet.. [-X
 Post Posted: Fri Dec 29, 2006 11:48 am
Its got a Blower ... why do you need a transbrake ?
 Post Posted: Fri Dec 29, 2006 4:03 pm
Still help for Drag Racing..My Buddies Dragster You have to use it at the line just to keep it from rolling..it will lope thru the brakes.. O:)
 Post Posted: Fri Dec 29, 2006 4:53 pm
MM a lot of those things need a full 12 volts to work properly so if you have your engine idling slow and or an under drive pully for the alternator on the crankshaft then this might "splain" it!
On my setup I have an under drive crank pully and unless the engine RPM is up above 1k sometimes there are problems. At any rate, like the others said, it might be a good idea to check yur electrical connections to make sure they are good.
Oh, and NO relay!
But I do have a question. Are you running a delay box? If so, what brand name is it?
 Post Posted: Fri Dec 29, 2006 9:03 pm
The only delay I have is the space between my ears after a few you know whats!
Ken, I think you hit it on the head. I sit in the garage and it works fine. Go for a spin, flip the auxilary switch, hit the button...nothing.
I've checked and rechecked the silly thing and all is good. So where's the solution?
Duane, have you been talking to my buddies? Actually the trans had a brake on it when I bought it otherwise I wouldn't have one. So now that I want to "play" I can't!!!
Maybe I should rewire with 14ga wire and solder?
 Post Posted: Fri Dec 29, 2006 9:06 pm
Maybe I'll pull the 12 directly off the starter.
 Post Posted: Sun Mar 11, 2007 1:43 am
OK Maybe a really dumb question Are you always trying the transbrake in 1st gear ? Mine only works in 1st and a while back my cable came out of adj just a lil bit and it (the transbrake) did what yours is doing work then not work I guess it depended on how hard i pulled the shifter back. I re adjusted the cable and it has worked fine ever since. If you like I can take it out on the track at Super Chevy and try it it out for ya :-$
 Post Posted: Sun Mar 11, 2007 1:49 am
Why no transbrake with a blower?
 Post Posted: Sun Mar 11, 2007 6:11 am
\:D/ \:D/ \:D/
make sure the curly cord is of heavy gauge aswell
regards
rod
The older I get the better I was
 Post Posted: Thu Mar 22, 2007 10:28 am
rodrocket wrote:
\:D/ \:D/ \:D/
regards
rod
Or that ALL of the curly cord wire is completely soldered to the switch on the wheel. In this case four strands wasn't doin' the job. I didn't notice this until I pulled the steering column while working on the interior. It's fixed now and I added a zip tie to take the strain off the switch which was probably the problem originally.
 Post Posted: Thu Mar 22, 2007 12:40 pm
Because you have all the low end you need to launch from an idle
