 Post subject: kill switch
 Post Posted: Fri Dec 01, 2006 9:21 pm
going to buy kill switch soon, along with fuse panel. Want a kill switch at shifter to shut down everything if needed, which do you guys prefer a big switch, push pull type or a electric soliod type with a toggle switch, which one is better?
http://www.s10dragracer.com/
 Post subject: Re: kill switch
 Post Posted: Sat Dec 02, 2006 1:15 pm
You want something that you Push or Turn to shut all power off, you dont want a pull type. And it has to be able to handle the maximum amount of current.
I would look at a 30 amp switch minimum and would prefer a 50 amp if you can find one. Maybe just get a Moroso Battery Disconnect switch.
What I had on my car was the Battery Disconnect at the rear of the car as required and I used a Key Switch on the Dash to shut " most " of the power off. I ran my Water Pump and electric fans on a seperate power wire.
jmo
 Post Posted: Sat Dec 02, 2006 3:07 pm
I want something next to shifter for safety, will have on and off switch in right rear
 Post Posted: Sat Dec 02, 2006 3:21 pm
Then I would look at a heavy duty toggle or push / pull switch.
