 Post subject: starter problem
 Post Posted: Sat Nov 25, 2006 10:37 am
got new truck yesterday, drove to work last night, this morning went to start and it cranked and cranked didnt fire so I turned key off and it still was cranking with out key on turned key back on and it fired. what is this is this a silinoid problem?
http://www.s10dragracer.com/
 Post subject: Re: starter problem
 Post Posted: Sat Nov 25, 2006 11:47 am
The only time I have had this happen was on a Ford Truck and it was the Solinoid. I dont see why it wouldnt happen on any other make.
So ... yes I would say its most likely the Solinoid but could also be the Ignition Switch.
 Post Posted: Sat Nov 25, 2006 3:09 pm
What Duane said! \:D/ \:D/
 Post Posted: Sat Nov 25, 2006 5:07 pm
What make of vehical is this ?
If it is a Ford it will be real easy to check the solinoid out, GM or Dodge will be harder but can be done the same way by checking it out with a DVOM at the signal stud and output side.
 Post Posted: Sat Nov 25, 2006 6:10 pm
Hey Spib! Is it your New Diesel? Also I have seen many newer trucks when you hit the ignition it will turn over on it's own until it starts! Really kinda cool. I know at work they have a 2006 Tundra and it does that and I think my buddies 2004 3/4 ton Chevy does it also....
Now if it's something older than..yes I agree on the solenoid.. \:D/
 Post Posted: Sat Nov 25, 2006 7:36 pm
no way if this was my new truck, they would have it untill it was fixed. It is a 85 shortbed that has another motor put in 350. anyways kept cranking so I turned the key off, hell it still was turning over, so I turned key back on and when it fired up it stoped cranking. This wont fly with me I have a remote silinoid, might try that, hey jody the pics help at all?
 Post Posted: Sat Nov 25, 2006 8:42 pm
Yes The pictures Helped me a bit..But I am still going to have to modify the frame rail to fit the top coil/over shock mounts. But I think I can get it lined out. thanks for your help! \:D/
 Post Posted: Mon Nov 27, 2006 8:01 am
solonoid or relay, on the chevy engines i have also had the primary start wire touch the battery cable at starter and keep engine cranking. seems the jump from begining to turn over would make a connection at that point and keep it cranking. somitimes starter would dissengage but still be running and burn starter up. you need to make sure that starter is not continualy running and do not use vehicle until fixed.
 Post Posted: Mon Nov 27, 2006 10:43 am
it doesnt crank after motor starts, either disconnecting battery or motor firing is all that will disengage, next step is, to pull start wire of and test with electical tester, there is lots of snow outside, so I might replace iginition box and see if that was it, thanks for replys, mark
