 Post Posted: Sun Feb 03, 2013 7:38 pm
What is the consensus on what size of brass screws, plugs blanks that a conversion will most likely need? 3/16 or 1/4" long???? I would rather not have to grind off material if possible, but I want to use the best size or more correct size per hole plugged. So, which is it or is it a combination of sizes needed for a 2 circuit conversion?
Back to the Superbowl... =;
 Post Posted: Sun Feb 03, 2013 7:55 pm
3/16 for most. I use 6-32 x 1/8 for idle feeds.
 Post Posted: Mon Feb 04, 2013 5:15 am
Hey John,
there is a guy on ebay that has 6-32 bleeds, any size you want. I used him, because Mcmaster Carr wouldn't ship to Australia.
I ordered them pre drilled, smaller than what I wanted, then opened them up as required.
http://www.ebay.com/itm/Holley-demon-qf ... e4&vxp=mtr
 Post Posted: Mon Feb 04, 2013 6:54 am
SGDCXCVI wrote:
Hey John,
Most Excellent Colin, THANKS for the link. \:D/ \:D/ \:D/
This is a Link that will make ordering alot easier. ;-)
Thanks Mark for your info also, good stuff. ;-) =D>
 Post Posted: Mon Feb 04, 2013 4:26 pm
That guy also has the jet extensions that Jmark preferred to use.
http://www.ebay.com/itm/Brass-Jet-exten ... 2300290aef
