8896-2HP metering blocks
http://motorsportsvillage.com/forum/viewtopic.php?f=6&t=9935
Author:  tsfso59 [ Fri Feb 01, 2013 10:27 pm ]
Post subject:  8896-2HP metering blocks
After reading the threads above about turning my 3 circuit to a 2 circuit, I started collecting parts and tools to do this. On all 3 circuits are you supposed to see the tube protruding behind the primary and secondary main jets? I cannot see any tubes at all....does this mean I have a 2 circuit already or was there some sort of change Holley did at some point?
I bought a pair of QFT 3 EB blocks and wondered where a good baseline would be for my combo. The majority of the info I read was for 4 or 5 hole blocks and only a small glimpse of 3 holers. My McMaster/Carr stuff showed up but I am still waiting on the hole gauges.
416 LS3, 13.6 compression, hyd roller 247/265 @050, Holley Hi-Ram intake, powerglide/brake, 5400 stall, 7400rpm trap
Don
Author:  jmarkaudio [ Fri Feb 01, 2013 10:45 pm ]
Post subject:  Re: 8896-2HP metering blocks
I've seen where the metering blocks were modified, the tubes cut up a little higher in the well. One of them way up, a bad thing. A 3 circuit block looks like this.
2 circuit.
Author:  tsfso59 [ Fri Feb 01, 2013 11:24 pm ]
Mine look like the top pic, but both have provisions for a power valve....on to the QFT blocks I go....
Further reading says to plug the top and bottom and use a .028 in the center for a get it started type of deal....any objections?
Author:  Ken0069 [ Sat Feb 02, 2013 12:06 am ]
On the 3 EB QFT blocks, use the top and bottom to start with and just put a blank set screw in the middle one.
