 Post Posted: Sun Dec 30, 2012 6:50 pm
Hi guys,
is it reasonable to measure the booster channel diameter with a pin poked through from the metering block side of the main body and are boosters consistent all the way through (since its not easy to measure through the bend)
Can someone tell me what a 750 street HP DP downleg booster should measure at (its an early one) just so i know if im close in what ive measured.
thanks!
 Post Posted: Mon Dec 31, 2012 8:05 am
From what I have seen is that the passage in the booster is the same size as the booster pin hole.
Not sure on the 4150 but the dominators I have done are 160....
I am sure Mark or Bruce could tell you what they are..
 Post Posted: Mon Dec 31, 2012 12:04 pm
Not sure off hand, but is should be around .145 - .150.
 Post Posted: Mon Dec 31, 2012 11:43 pm
i had a bit of a fumble and a 0.155" pin was "close" if a little on the loose side, if i can dig up a 0.160" ill have another look.
does that seem a bit on the large side to you guys?
Ill grab the main body part number and post it, theres every chance ive cocked up the measuring somehow =;
 Post Posted: Tue Jan 01, 2013 10:31 am
It's a little more than I might use, but should be OK.
Users browsing this forum: Google [Bot] and 7 guests
