 Post subject: Question on power valves
 Post Posted: Sun Sep 30, 2012 11:46 am
I think I may have a power valve blown in my carb. Is there a simple way to test for this as I've not had an issue with them before and need to know what to look for. Thanks in advance. Dave
U can step on the brake,
U can step on the gas,
But step on ur crank,
Ur gonna get passed!
 Post Posted: Sun Sep 30, 2012 12:49 pm
Dave ruptured PVs will cause rich idle and part throttle conditions as fuel is leaking into the manifold due to engine vacuum.
There is a tester made to check them with but as cheap as the PVs are you might just want to replace them to see if that fixes your problem.
 Post Posted: Sun Sep 30, 2012 5:03 pm
I was told to try to turn the center piece. If it turns or moves it is bad. What ken says it true it will be fat.
