 Post Posted: Mon Sep 03, 2012 8:28 pm
just wandering
1.26 5.64 123.8 8.84 152 mph on gas
 Post Posted: Mon Sep 03, 2012 9:41 pm
So first we need to know what do you plan to run E85 in, ie, what engine combo? :-k
 Post Posted: Mon Sep 03, 2012 10:09 pm
What ken said. Once we know that we can work on a setup for you. There will be some changes to boosters, pins, main wells, air bleeds, needle and seat, etc.
 Post Posted: Mon Sep 03, 2012 11:08 pm
engine is a cam only ls3 about 500 flywheel
 Post Posted: Tue Sep 04, 2012 6:13 am
Does E85 work well with nitorus???????
 Post Posted: Tue Sep 04, 2012 4:18 pm
just e85 for the motor no bottle .
 Post Posted: Tue Sep 04, 2012 4:23 pm
The booster banjo's need to be opened up, metering blocks need some serious drilling or you can use 4150 methanol blocks, and some small calibration differences in the emulsion and idle circuits. Of course larger jets as well.
 Post Posted: Tue Sep 04, 2012 4:28 pm
Not cheep to do the swap but you will have a smile on your face every time you fill that 5 gallon can up and walk away with change from that 20 dollar bill you gave the attendant =; I know I do ;-) ...
 Post Posted: Wed Sep 05, 2012 12:06 pm
For me it has. Have you heard of anyone having issues with E85 on nitrous?
 Post Posted: Fri Sep 14, 2012 8:46 am
nope mine is fine ...seems the nx tune only needs a fuel psi raise to run it as they are pig rich on gas
isnt that 1050 dom alittle big for your set up at 500h/p
converting a old 750-850 based carb over will be cheaper and alot easier to tune
 Post Posted: Sat Sep 15, 2012 4:22 pm
i started with a 750 dp and then a 850 then a 1050 4150 proform than this 1050 dom and this carb runs faster on both ends \:D/
