 Post Posted: Tue Aug 07, 2012 4:33 pm
How about some spec's on that motor? Looks like your on the right track as it seems like Holley always puts to big of a MAB..
Bruce mapped out on of those and looks like it could use less emulsion also #-o
Hey Barry,
what are you looking at in that dyno sheet that say's less emulsion?
We had an engine on the dyno on Monday and I want to try and understand more.
Cheers Colin.
 Post Posted: Sun Aug 26, 2012 6:58 pm
Did make a mistake main jets at the dyno were #94 not #96 , so I used #94 jets and #27 air bleeds , #26 air bleeds where a bit rich and lost about 4 hp
 Post Posted: Mon Aug 27, 2012 5:06 am
But what did the curve look like?
It might have been even happier with a .026 and a 93 jet.
 Post Posted: Mon Aug 27, 2012 5:25 am
This is the .026 air bleed #94 jet dyno sheet , I feel the curve is a bit smoother , but did not try a #93 main jet , this was the last pull and I did leave it this way for the street.
 Post Posted: Mon Aug 27, 2012 8:18 pm
Is that a true o2 sensor getting Air Fuel Ratio or is it calculated A/F from fuel consumption and Air consumed?
 Post Posted: Mon Aug 27, 2012 8:48 pm
Superflow turbine that goes on top of the carb. , thats calculated ? Dyno is a 902.
