Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post Posted: Thu Oct 04, 2012 11:20 am
nomad wrote:
74 firebird461 wrote:
So Do you put the boosters in the banjo's first then install banjos in carb? Probably going to try this after this race.Anything special to do to the booster's etc when installing them?
I use one of those "General" tools brand automatic center punches you find at Lowe's. The body is made of aluminum or brass. The punch end goes into the stake pin and centers the punch in the stake pin. It also keeps the punch body from jumping out of the stake pin. The body of the punch is rounded and fits the flare of the stake pin perfectly so no damage occurs while tapping the pin in place.
So something like this? I don't have a lowe's by me, a menards tho .
http://www.lowes.com/pd_186380-56005-70 ... Id=1053205
74 Firebird 3580 lbs
 Post Posted: Thu Oct 04, 2012 11:28 am
Remember also to put some red lock tight on the pin that goes into the banjo..
 Post Posted: Thu Oct 04, 2012 11:32 am
They aren't tight enough without it? When I sand the banjo , is it just the side that the stake tube goes in that needs to be sanded down on each side to fit in my older dom? I also install the booster in the banjo first correct, then install banjo into carb bore? I see they have this at harbour freight. will it work ?
http://www.harborfreight.com/spring-loa ... h-621.html
 Post Posted: Thu Oct 04, 2012 12:08 pm
You will need to "file" down the sides, (not the face that the pin goes in) of the banjo on the pin side..
I lock tight them but if you don't think there is a need to then don't.....
 Post Posted: Thu Oct 04, 2012 1:12 pm
That is what I meant sorry, just the side that the pin is on not the other thinner side. Sorry should have been more clear, thanks!
 Post Posted: Mon Oct 08, 2012 3:05 pm
That one doesn't have the rounded end like the one that I have. It needs to be a "General" brand. They're available all over.
 Post Posted: Mon Oct 08, 2012 3:12 pm
This is a pic of my booster stake pin puller.
Ignore my sloppy welding job. The screw is a 10-32 thread. I tap the stake pin and pull it out with the puller. It takes surprisingly little effort considering how hard they are to pry out.
My initial reason for threading was so the pin may be re-used in an emergency. The threads aren't deep but, I no longer think that is a good idea. The threads my upset the flow. Maybe a self tapping screw may ne a better idea.
