 Post Posted: Fri Jun 29, 2012 10:02 pm
What fuel cell company will do a special handling unit without drilling the openings? I am doing an under floor custom install and it will be a better fit if I can chose were the fittings are installed.
Need a 3 gal up right like this
http://www.jazproducts.com/drag_fuel_cells.html
 Post Posted: Sat Jun 30, 2012 7:38 am
Why not give'em a call and see what they will do?
http://www.jazproducts.com/contact_us.html
 Post Posted: Sat Jun 30, 2012 12:32 pm
What about a custom made aluminum cell. Make it any shape and size ... then put the fittings where you want.
 Post Posted: Sat Jun 30, 2012 8:56 pm
X2 as I was thinking the same thing..
 Post Posted: Mon Jul 02, 2012 7:52 pm
Jaz sells the unfinished cells, "no problem, do it often." It will have one 3/8 hole in the filler opening area. [that is how they "blow" the product]
The price is about 1/2 that of a finished cell. Just what I needed.
 Post Posted: Mon Jul 02, 2012 9:12 pm
That's good to know Larry as I may have to go that route If I can't get a different filter on my car but if the exit hole was in a different spot it would work... =;
