Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: data help
 Post Posted: Mon May 28, 2012 7:02 am
Dang!
With a zero to 20 scale it will make almost anything look good! O:)
 Post Posted: Mon May 28, 2012 9:38 am
Thanks for the "Plain English" in explaining to to do it Ken =; ...
You're welcome Barry but to be honest, I taught myself something in the process as this new "snipping tool" in Windows 7 cuts out about 3 or 4 additional steps that I used before to accomplish this same task using MS Paint or Adobe Photoshop.
Just a shame that Windowz is so susceptible to hacks!
But it's pretty easy to do this in Linux Mint also though. ;-) And did I mention that it's FREE? =;
 Post Posted: Mon May 28, 2012 10:15 am
Scott Smith wrote:
Dang!
Sorry Scott that it's not a log from a Race Pack as they were not around when I purchased
the Computech...So why don't you post your race pack data for Ron...
 Post Posted: Mon May 28, 2012 10:43 am
Scott Smith wrote:
Dang!
Because mine suck! =;
I sent the intake off to try to fix my troubles. =;
 Post Posted: Mon May 28, 2012 10:47 am
Ken,
In win7 i just hit Alt + printscreen
Then
Click start type paint in the search bar, open paint click paste then save as jpg.
 Post Posted: Mon May 28, 2012 10:55 am
Thanks but you can teach an old dog new tricks \:D/ ..Thanks for the "Plain English" in explaining to to do it Ken =; ...See I can follow instructions \:D/ \:D/
Here you go Ron this is probability one of the best runs I have to show you as far as O2.log.
I know it's not perfect but did run good......That run was a 8.16 at 170.. =;
Barry, That AFR looks really good, even if it is a 0-20. Greg Kelly told me good afr's numbers should be 12.7 to 13.1. That seems tight and yours look close to that. It might take me a long time to get it that flat, but with the help of this forum I'll get it there.
 Post Posted: Mon May 28, 2012 11:08 am
Ron I don't think you will with that carb you have but will with the conversion or maybe with the 3 circuit blocks the BLP has with the separate idle not in the main well...
I deleted all the logs from my 3 circuit carb but do have some pictures of what the exhaust ports looked like before and after,,And the after was just running it in the driveway to try and tune the Idle some..
It also stopped frying your eyes :-
 Post Posted: Mon May 28, 2012 11:56 am
I plan to go the 2 circuit route. I have a 2 circuit (80186), main body that I changed boosters in and I can convert this 9375. Thanks for your help.
 Post Posted: Mon May 28, 2012 1:35 pm
Scott Smith wrote:
Ken,
Then
Using the snipping tool is quicker than that and you don't have the entire desktop saved, ie, only make the image of what you want the FIRST time. MS Paint not even needed.
 Post Posted: Mon May 28, 2012 2:19 pm
George recommended a little tool years ago that I still use called MWsnap. It allows you to draw a rectangle around what you want to screenshot then click to capture. Then file save and you're done. I usually use IRfanview to view and resize/resample images. So simple a caveman can do it.
Oh yeah, both those programs are free so even Ken has to like them 8-[
 Post Posted: Mon May 28, 2012 2:49 pm
The Windows 7 "snipping tool" does the same thing Chuck, ie, you draw that rectangle around what you want then save it.
Oh, free is good but they still require Windowz to be able to use them. Linux on the other hand IS totally free. ;-)
 Post Posted: Mon May 28, 2012 6:02 pm
Quote:
Note the Alt- part. Alt-printscreen copies only the current window to clipboard, not the whole screen.
That is correct,
Only the active window is captured. Ctrl + Printscreen copies the whole desktop.
 Post Posted: Mon May 28, 2012 6:03 pm
I learned me something Ken. I like the sniping tool! Only problem is i'm on a XP machine 50% of the time.
