 Post Posted: Thu Apr 26, 2012 9:02 pm
Does anyone have a base setting for this?
It has screw in air bleeds. It seems fat all over but runs the quickest ET with 135-160 jets and no powervalve...(I realize that is a big swing need more time with the carb) Just wanting to get it closer. Seems fat in the burnout and during shutdown.
 Post Posted: Fri Apr 27, 2012 11:30 am
IS this a factory alcohol carb or was it converted by somebody? Bob J
 Post Posted: Fri Apr 27, 2012 6:31 pm
Square the jets. Start about .160 and go up or down for best MPH. You don't want jetting staggered that much with no PV's.
 Post Posted: Fri Apr 27, 2012 7:25 pm
How big are the angle channels on those things?
 Post Posted: Fri Apr 27, 2012 11:43 pm
No Idea on the angle channel Scott.
Tried to run it tonight and would not run. Loaded it up.
May mess with it some more. Just need all the info I can get.
I am not sure if it is a factory alcohol carb or a converted one.
 Post Posted: Sat May 05, 2012 9:39 am
hey jody,
my quickfuel 950 alcohol carb is jetted 150 in the front with a power valve and 160 in the rear,i dont have to o2 sensor hooked up yet but it seems to work very well,out of the box quickfuel had it jetted "square" with 160's but i run a power valve in the front
 Post Posted: Tue May 08, 2012 11:34 am
What about air bleeds?
 Post Posted: Tue May 08, 2012 6:16 pm
primary main jet-160
secondary main jet-160
idle air bleed 53/53
hi speed bleed 28/28
primary nozzle 55
secondary nozzle 55
needle and seat .150 stainless steel
jody this is what the tag from the carb said,like i said the only thing i changed was to pull the plugs from the power valve channel restrictions and put a power valve in the front and reduced the primary jet 10 sizes.....works perfectly
