 Post Posted: Mon May 21, 2012 8:59 pm
does it matter which end the regulator is installed on the fuel log? Is it the same if the fuel from pump enters the rear and the regulator bypass exits the front? Seems to me it will work either way, am I correct?
The plumbing simply works better with the inlet at the rear and the regulator on the front.
