 Post subject: 3 e holes
 Post Posted: Sat Mar 03, 2012 12:29 am
The blocks that I plan to use on my 2 circuit 1050 Dominator have 3 holes that are about .027 diameter. Is it necessary to plug the middle e-hole or should I try it with 3? Angle channel is drilled to .159 and IFR is moved to the bottom.
 Post subject: Re: 3 e holes
 Post Posted: Sat Mar 03, 2012 6:39 am
If you want to play around you can try it with 3. My Quikfuel blocks have 3 and I started out with the middle plugged but later moved the plug to the top and got a noticeable difference in AFRs from that, ie, closer to flat line. Your mileage may vary!
Always remember that most of this stuff isn't written in stone, ie, all engines are different and as such usually want something a little different.
