 Post subject: Metering blocks
 Post Posted: Tue Feb 28, 2012 8:11 am
Is one block better than the other for a race only application on a 80186-1 with BLP boosters? The top block is the original block off the 80186-1 and has the plugs at different heights. The second block is off a 7320 and has the main well plugs even. I will drill the cross overs and move the idle feed.
 Post subject: Re: Metering blocks
 Post Posted: Tue Feb 28, 2012 8:48 am
Use the top block Ron. The blocks with the flat mailwell plugs have some funky emulsion stuff or something like that. The top block with the recessed plugs is the perferred one to use.
