 Post Posted: Tue Feb 21, 2012 8:20 pm
I have a SF 600 bench for doing head work....does anyone have a pic of an adaptor so that i can flow a carb on this bench....
Do you flow each hole individually or the 4 all together?
Also can you connect the 2nd manometer to look for signal strength??
 Post Posted: Tue Feb 21, 2012 8:54 pm
Don't have it for a picture, but I made one out of clear plexiglass to bolt on an SBC head adaptor, centered one hole over the middle of the bore. I used clay to seal the vacuum crossover passage between the bores on the bottom. BLP has a Superflow 1200 and can do half the carb at a time. And yes on the manometer
