 Post Posted: Thu Jan 19, 2012 9:45 am
Currently im running vp 110 in a 11.50 compression sbc drag race only, is there a better fuel to use maybe c12 ?
JEFF WINTERS
1986 SS MONTE CARLO
406 SBC
 Post Posted: Thu Jan 19, 2012 10:47 am
While I can't answer your question about a better fuel, I can tell you that I run C12 in my 15.2 to 1 18* SBC and at some point may even go to E85 once I see it run in a similar compression engine. jmarkaudio's brother is currently running E85 now in a 14.5 to 1 SB2 engine in his Corvette roadster.
Having said that, if it was my engine at 11.5 compression I'd be looking at E85 if it's available in your area.
 Post Posted: Thu Jan 19, 2012 11:35 am
Higher octane fuel won't necessarily yield better performance. IMO it will likely slow you down. I went from a 110 fuel to a higher octane with an engine that was around 13.5 to 1 and my car was noticeably slower.
 Post Posted: Thu Jan 19, 2012 3:15 pm
With your compression Av-gas would be a good start, another that is oxygenated but has a lower vaporization curve would be VP MS109. Be ready to jet both up a little.
 Post Posted: Thu Jan 19, 2012 3:57 pm
We ran 110 at 10.5:1 and then went to 14:1 and run VP113. Very consistant.
 Post Posted: Mon Jan 23, 2012 1:24 pm
At 11.5 , you shouldn't need any more than a good 110 . Anything more would only waste your money .
Mike Croley
Master Dist. for Renegade Racing Fuels
www.renegadepro1.com
