 Post subject: How's It Sound?
 Post Posted: Mon Jan 09, 2012 10:53 pm
We've all got our pet peeves regarding questions from other rodders. Mine was always the "How's it sound question?" My reply was always to the effect, if it's got open headers it sounds great.
You all know I've come to this carb thing later in life than most. So, it's been a bit of a surprise that "How's it sound?" really does seem to matter. I began to notice this with all the dyno testing we've done lately. It really became apparent at the Carb Challenge. It was easy to tell which pull was was going to be better than some others.
Now I've noticed that I pay attention to the faster cars as they go by my pit area. Not all that many sound like the engines are happy. Some are downright ragged, cars I would think should be better. Cars that probably have boutique carbs on them.
You other newbie carb fiddlers noticing this, too?
 Post subject: Re: How's It Sound?
 Post Posted: Mon Jan 09, 2012 11:34 pm
http://www.youtube.com/watch?v=x-jMsrl5EIw
This is a 417 cube Cleveland through the mufflers. The engine makes over 780hp with a 1042CFM SmartCarby on it. It is regular street driven, its not a race car. It makes 300hp at the wheels in top gear at 60kph( 37mph our speed limit). It runs at 40kph (25mph)in top gear (manual not auto) without snatching and pulls away with WOT. It passes noise laws and passes emissions. The engine was first built with a Dominator on it and it didn't have this sound, it was dull and bassy. It made similar power but had less response, used far more fuel and couldn't pass emissions.
Listen to the sound how it changes from the burnout and the RPM before the launch and compare it to the sound as it goes down track. You can hear the other car, its a dull bass sound (conventional). The sound in the burnout and pre launch is smooth and snappy, the sound during the run is sharp and supersonic. We have chassis dynoed it with pipes on pipes off etc it makes no difference it kills your ears.
During the run the sound is a sharp hard crack, Its got this crack at basically all revs when under serious load. That is the sound of supersonic flow when the valve opens. Engines that make that sound (you have to correctly identify it compared to an exhaust resonance) are usually really good efficient engines. They make high power from little fuel. engines that sound dull and more bassy are making high levels of CO with high levels of unburnt HC and some unused O2 in the exhaust. Basically they could be better.
 Post Posted: Mon Jan 09, 2012 11:45 pm
Nomad, think back about the sounds in the carby contest, the better carbys would have made that cracking sound or got close to it. Marks run sounded different to the others I heard.
 Post Posted: Tue Jan 10, 2012 6:23 am
Do you mean combustion efficiency, as in the more efficient the combustion the sharper the tone?
Hysteric
 Post Posted: Tue Jan 10, 2012 8:28 am
http://youtu.be/W9Yg-w5Qg3Y
 Post Posted: Tue Jan 10, 2012 8:29 am
http://youtu.be/N2dRoJX4wfg
 Post Posted: Tue Jan 10, 2012 10:51 am
Mine is like that. When I have a helmet on it's different, of course. I generally wear ear protection when working on it but one day I stood on it coming down the return road with bare ears. Man, that hurt in a way my previous builds never did. Jmarks SB2 will do that to me also.
 Post Posted: Tue Jan 10, 2012 12:22 pm
Hysteric
Yes.
 Post Posted: Thu Feb 09, 2012 1:03 pm
So does mine have that sound?
I know its dirty, It will be cleaned today, it has been sitting in the shop for the last two months.
video
74 Nova
 Post Posted: Thu Feb 09, 2012 6:00 pm
No it doesnt. I see the amount you are opening the throttle and the engine isnt doing high rpm in that time.
 Post Posted: Fri Feb 10, 2012 2:13 am
Shrinker........Do you have another example for us?
Hysteric
 Post Posted: Fri Feb 10, 2012 6:12 am
No.
 Post Posted: Wed Feb 22, 2012 3:16 pm
At the time of that video that boat was fitted with a low powered engine. World products sportsman 2 heads on 12.5:1 comp. The video was also taken on the first tune of the engine, eventually the team let me retune it (I leaned it a little) and it went a further 6 mile per hour faster than that video. Its record for the season was 19 wins, 2 seconds and 1 crash from 23 starts. You can hear the engine well in that video and it does have the distinctive Smartcarby sound. The sound volume per exhaust event is more even indicating more consistent AFR per event. The engines fuel consumption dropped from 63 liters per meeting to 47 by using the Smartcarby.
Since those days most of the other competitors have moved to the NASCAR motor deals you can get nowadays and so has this boat, its a Dale Earnhardt cup motor now. Its still got a Smartcarby on it, a 1340CFM one and its still winning, so far 10 wins in a row. It uses 8 liters of fuel per race the others use 14, so go figure that out everyone.
 Post Posted: Sat Feb 25, 2012 8:30 pm
Shrinker, tell me about Jeff Taylor's (near lane) sound. It gives me goose bumps every time I watch it.
http://www.youtube.com/watch?v=tsXOdr48gZ4
 Post Posted: Sat Feb 25, 2012 9:32 pm
delete
