 Post Posted: Tue Dec 20, 2011 11:23 am
Was asked about this some time back but didn't have an answer at that time. Got to looking this week though and it appears that a 3 circuit Holley gasket can be used with a 2 circuit metering block? :-k There is one hole in the 3 circuit gasket that's not in the 2 circuit one but it doesn't appear as it would be a problem for the 2 circuit blocks? :-k
Anyone else notice this?
 Post Posted: Tue Dec 20, 2011 3:53 pm
Mark uses them and told me the part
# he uses but can't remember it now #-o ..
Anyway the hole for the booster passage is
alot larger...
 Post Posted: Wed Dec 21, 2011 4:45 pm
Yes, you can use a 3 circuit gasket in a 2 circuit. There's a catch however. The 3 circuit gasket has a tab at the top. The stock 3 circuit metering blocks have a cutout to accomidate this, the stock two circuit blocks don't.
The BLP metering blocks are flat and do not have the compression stop built into the block. Thus this swap will work. The QFT blocks have a compression stop also.
You might be able to shave that tab off the gasket to get it to work on stock metering blocks.
 Post Posted: Wed Dec 21, 2011 5:53 pm
FYI guys, I just cut the top of one of those "quality" pink/red 3 circuit gaskets with a pair of SHARP tin snips and it worked great!! You can use a 2 circuit gasket to mark how much to cut off, which is like a 1/16" or so. \:D/
 Post Posted: Thu Dec 22, 2011 10:28 am
I'm thinking that my personal parts stash will now include 3 circuit gaskets only. The tab won't matter for me. And I am now running ........GASP, CHOKE, CHOKE! a 3 circuit on my custom main body carb.
 Post Posted: Thu Dec 22, 2011 11:23 am
TRAITOR! Image ;-)
 Post Posted: Thu Dec 22, 2011 12:21 pm
WHY???????????
 Post Posted: Thu Dec 22, 2011 4:33 pm
I've been playing with BLP wide body blocks on this carb. I've run it both ways, as a 2 circuit and a 3 circuit. This one seems to have a better O2 than it does as a 2 circuit.
However, I'm getting a bit off topic here. My apologies to the OP.
 Post Posted: Thu Dec 22, 2011 4:56 pm
WHY???????????
Just because. After all, it's been proven that a 2 circuit Dominator out performed the others at the "Shoot out". ;-) But I guess in the end you have to do whatever you feel is best for you regardless of whether it's right or not. Even a blind squirrel picks up an acorn once in a while and I guess someone might stumble on to a 3 circuit tuneup that actually works? :- ;-)
 Post Posted: Thu Dec 22, 2011 9:36 pm
Ok then lets here about it and start another thread =; ...I got shot down on doing one to test with :-#
