 Post Posted: Mon Sep 19, 2011 12:06 pm
Anyone know the correct size/correct bit to use to step the booster? I am thinking of trying to accopmlish that while the boosters are in the carb.
 Post Posted: Wed Sep 21, 2011 11:02 am
If anyone is interested it appears 12mm/1/2 would work.
 Post Posted: Wed Sep 21, 2011 12:00 pm
Actually 13 mm would be closer to 1/2". 25.4 mm = 1"
 Post Posted: Wed Sep 21, 2011 3:07 pm
I haven't replied to this one as I really don't understand what you're trying to do? A little more info might help and also may keep you from chasing rabbits, ie, doing something that someone else has tried that DID NOT work?? :-k
 Post Posted: Wed Sep 21, 2011 10:16 pm
I think he wants a stepped booster without replacing the stock ones. You will have an issue holding them steady enough to not break them in the carb, they are not that tough. I can do them for the cost of the boosters and shipping, but if you have someone local with a booster tool it would probably be cheaper. You might be able to do it, but be prepared in case you break one. The new Braswell boosters I have here are .520 at the step and flair out from there.
 Post Posted: Thu Sep 22, 2011 6:20 pm
Thanks Jmark...decided to leave them alone...will have stepped ones installed on the next main body I buy.
 Post Posted: Mon Oct 03, 2011 10:15 pm
I do different size steps -- depends on the carb size and application. 1/2" is good for bigger 4150's
PS. depth of the cut is important too.
 Post Posted: Fri Oct 21, 2011 9:20 pm
Pal of mine called the other day and informed me he has been able to machine a step in an installed 4150 booster. He made a fixture to center the endmill in the booster and support it to avoid breakage. I've been trying for two days to get over there and see how that works.
 Post Posted: Tue Oct 25, 2011 7:32 pm
I got over to my buddy's to see the results of his on carb booster step machining. I didn't get to see this in operation but, I saw the result. It was everything he said it was. Maybe "you know who" can make a fixture so he can do it also.
