 Post subject: Carb Mounted Backwards
 Post Posted: Tue Jul 21, 2009 10:45 am
I've had some issues routing the morse cable for my throttle without too many bends in it and came to he conclusion I needed to have the cable attach on the right side of the carb (looking from behind engine). I run a 1050 jetted square, and have swapped around the bowls and jet extensions to the rear bowl, which is now the primaries. The cable is now routed with one single bend in it, works much smoother, so I'm just looking for the opinions on running the carb like this.
The altered has a front mounted pump and cell and I run 7.5psi at the carb, I don't see it being an issue but anybody got any thought on it ?
 Post Posted: Tue Jul 21, 2009 12:28 pm
Without a PV in the primary side, it makes no difference at all. Remember, ppl have run thsese things sideways for a long time so backward won't be an issue.
 Post Posted: Tue Jul 21, 2009 8:43 pm
What Ken said, it doesn't know which way it's going =;
2009 Carolina Dragway Box Class Champ
 Post Posted: Tue Jul 21, 2009 9:36 pm
TMC_Hurst_Olds sent me an Email cuz he couldn't figure out how to post here stating he ran one backwards on a ski boat for 35 years! \:D/
 Post Posted: Wed Jul 22, 2009 3:23 am
cool, no PV's so I'm good to go
Thanks all
 Post Posted: Wed Jul 22, 2009 10:03 am
Guys have been running carburetors backwards on dragsters for decades. Just make sure you have your jet extensions and floats pointing in the right direction and you'll be good to go.
Doug Schriefer
Braswell Carburetion
Check us out on FaceBook https://www.facebook.com/pages/Braswell-Carburetion/320755068324
 Post Posted: Wed Jul 22, 2009 11:24 am
yep all in the right place, swapped jets extensions and bowls. Makes sense to run it backwards in a single seater as the cable's better routed on the right regardless of whether it's front or rear engine.
 Post Posted: Fri Jul 24, 2009 6:49 pm
we run them backwards also.. ends up they go realy fast in reverse. =;
 Post Posted: Thu Sep 03, 2009 2:43 pm
ran mine tother way round since I put a 4500 on it.. no probs..
Sam
http://www.doubledensity.co.uk
