Post new topic Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post Posted: Mon Feb 04, 2008 10:57 am
yeah it's odd Ken, after studying it, I figured the groove in the linkage would need to be longer as the length of the slot effectivly governs the stop / closed position of the secondaries. I may get it milled (or precision filed !) slightly longer to get them closed as it shouldn't affect the rate they open as this is governed by the profile and the other end of the slot.
 Post Posted: Mon Feb 04, 2008 11:06 am
Yeah Phil, I was thinking that too.  It's good to see you have enough mechanical savvy to figure out how to fix it.  That just makes me more confident that you'll get the rest of it done OK.  Just remember to use the locktite when you put the screw back in it!  ;-) I found mine loose last summer AFTER I pulled it off of a friends engine.  Wouldn't have been long and it would have done some damage to his stuff.  Got lucky for a change I guess. =; A blind squirrel will pick up an acorn occasionally.  It was my turn that day.
 Post Posted: Mon Feb 04, 2008 11:39 am
split washer, loctite and split pin, I got too much £££'s in there to let a nut go through it all !
mechical savvy , I have my momments (not often though !).  Getting more of a gist the more I read on the 2 circuit conversion but I'm still unclear where and what to do.
 Post Posted: Mon Feb 04, 2008 12:31 pm
Yea the pin gauges come in handy for several reasons.
Verify jet sizes in case someone drilled one.
Verify air bleeds for same reason.
And gauge all of your existing holes.
Brass set screws
http://www.mcmaster.com
You need one box of each.
10-32 x 1/4 Part Number:  92991A825
8-32 x 1/4 Part Number:  92991A190
6-32 x 1/4 Part Number:  92991A144
Drill bits
61-80 Part Number:  31055A64
1-60 Part Number:  31055A62
Pin vise  Part Number: 8455A16
 Post Posted: Mon Feb 04, 2008 12:39 pm
BTW I got my drill bits locally
Got the 1-60 at Grainger
And the 61-80 at Alabama Machinery
There is a trick to drilling the small holes. Tuner forgot to tell me until I had already broken a bit.  [-(
For example a .026 hole.
Put the set screw in your cordless drill and the .026 drill in your pin vise. Turn the drill very slowly about 25 RPM and gently feed the drill bit being very careful when it breaks through. I had a second cordless drill with a #60 drill in it to start the hole and make sure it was on center. Then finished it up with the .026
The finished product will look something like this.
Doh I almost forgot
You need taps too. Bottoming taps seem to work better on the idle jet.
 Post Posted: Mon Feb 04, 2008 12:44 pm
This is where the T Slot jet goes.
Once you start a drill in there for the 10-32 that brass insert will come out.
 Post Posted: Mon Feb 04, 2008 1:37 pm
It’s a PITA but the adjustment for the secondary linkage is done by bending the link that connects the lever on the throttle shaft to the bell-crank (in the bottom of the carb).  You should use a 4-hole spacer or 4-hole plate to block off the bottom of the carb from the manifold.
 Post Posted: Mon Feb 04, 2008 2:10 pm
Scott, what's all them damn air bleed holes open for? Image Didn't we teach you better than that? ;-)
 Post Posted: Mon Feb 04, 2008 2:58 pm
LOL! That was my old 3 circuit block I removed. The pics are just for illustration purposes.  =;
 Post Posted: Mon Feb 04, 2008 7:30 pm
Thanks for those pic's Scott!!!  It makes thinks a bit clearer now =;
Did Tuner give you some kind of "what to drill and what size to start" with
and then go from there??????
 Post Posted: Mon Feb 04, 2008 9:18 pm
Yes he did. But it is different for different apps.
I'll have to dig my notes out.
 Post Posted: Tue Feb 05, 2008 6:49 am
Is it possible to do the mod to a 3 circut and lean out the idle??
 Post Posted: Tue Feb 05, 2008 8:22 am
can you not lean it with the idle screws currently Barry ?
I had a fat idle because it was basically running on the T Slots, I'm hoping to close the throttles (as my secondaies were being held open by the primary linkage) and go back to tuning the idle with the idle screws/ bleeds and installing additional bleeds to create the controlled vacuum leak (instead of drilled throttle blades)
Hopefully with the TSJ's and the 2 circuit conversion I should get a handle on it and get it running clean and performing well in a safe rich zone.
Ken/ Tuner / Scott, you have an audience of 2 ! I think Barry and I get the concept but like Barry said, a guide as to what to measure, what to drill, what to tap and which points will need to be tailored or tested dependant on application would really help. I'd be happy to document and photograph the process for others ?
 Post Posted: Tue Feb 05, 2008 9:21 am
I don't know about you guys, but this thread has gotten a bit large and would be confusing to someone new interested in doing this.  So, I'm going to start another thread for a two circuit mod and lock this one if no one has any objections.
 Post Posted: Tue Feb 05, 2008 10:15 am
Ken , go ahead and lock it....If you want =; ...Will post on  new subject =;
