 Post Posted: Sat Nov 24, 2012 12:05 am
Chev 355,flat top pistons, vortec heads, hyd roller,cam specs IN 210 @.05, EX 212 @.050, 112 LSA , .450 lift, I & EX, w 1.5 rockers. cam is installed +4*. Cranking compression, at room temp is 185. This engine was built for propane use,in a daily driven work truck, but if propane isn't available, what octane would be used. Thanks for any input guys
 Post Posted: Sat Nov 24, 2012 12:40 am
That can run on RON 92 as available in Australia. Personally owned an engine nearly the same. The regular or lowest grade of petrol. Interesting to see what others say about your stew.
