just primer wrote:
So if a gasket comes off without any resistance like it is glued down then that must be the leak going to the outside instead of the piston right?
Just primer
NO, not necessarily. Since you got no idea of what has been done to that thing in the past, you really don't know if those are the original gaskets. Some stick, some don't.
If there's no evidence of water having been in the cylinders then I don't know what to tell ya as without doing some pressure testing it's hard to know what was leaking. Then again, if it has been sitting for a long time, who knows what was wrong with to begin with.
Did you have them drain the oil out yet?
