Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post Posted: Sat Jan 12, 2013 5:15 pm
JEFF69Z28 wrote:
Block was cracked from a head bolt hole into the #6 cylinder.
I had a 400 block poured with hard block to the water pump holes do that on #1 in the 10 o'clock head bolt hole. Crack was down the cylinder about 1.5 inches. Boat anchor after that.
 Post Posted: Sun Jan 13, 2013 7:30 am
Now you have a good excuse to buy a Dart block.
551D Super Pro - 8.51 @ 158
-- Albert Einstein
 Post Posted: Sun Jan 13, 2013 9:00 am
I had the exact thing happen to me. Left a partial filled freshly machined 400SB in the basement until spring. Took it out to the garage for assembly and it was cracked in both 4 and 6 cylinders from the deck to the level of the hard block.
I had that block squared to the world, 1200 clams in 1991 dollars and it was junk. I got short of breath when I dropped it into the dumpster at work.
At the time aftermarket small blocks weren't really available for guys like me.
