 Post Posted: Tue Sep 06, 2011 11:52 am
any opinions on a sbc standard journal diameter of 1.868, and how much lobe should be the limit for longevity of the setup ?
also, any opinions on running a .470-.475 lobe on a .910 base circle and the same 1.868 journal, as far as longevity is concerned.
probably with 280 lbs on the seat and approx. rate of 600 lbs
1.70-1.75 rocker
thanks jerome
thanks jerome baker
proud owner of, RFD 18 DEGREE MONSTERS
 Post Posted: Tue Sep 06, 2011 8:24 pm
1.70-1.75 rocker
thanks jerome
Thats a lot of lobe for such a small base circle and that much rocker and spring pressure. I'd be looking for ways to fix the clearance issue before resorting to a cam like that. Small Journal rods and 3.875" stroke will clear with standard base circle and no grinding on the rods (Compstar). Honda journals and 4" stroke should work also. I know some do some minor grinding/milling to the rods for clearance.
It'll probably work like that but I'd keep a close eye on things.
 Post Posted: Thu Sep 08, 2011 3:18 am
I agree with fixing the clearance issues.
If I had to run a small base circle cam I would cut back on the rate of the lobe just a little and use a larger diameter and larger roller diameter lifter. Get with a good cam grinder and discuss doing that.
www.adgersperf.com
