 Post Posted: Wed Mar 02, 2011 1:43 pm
SX10 got a set of Pro Comp heads from MargaritaMan a few years ago for his B&M Blower engine he's building for his Corvette. Those heads came with some Pro Comp 1.6 rockers that he decided not to use so he ordered a set of Scorpion 1.65 rockers to replace them. He recently was doing a mock up of that deal and noticed that his valve cover wouldn't pass by the push rod side of that rocker arm??
So this morning he called me and I loaned him one of my Moroso tall valve covers off the POS SBC I have on the engine stand to see if it had enough clearance. IT DIDN'T AND HE STILL HAS CONTACT BETWEEN THE PUSH ROD SIDE OF THE ROCKER ARM AND THE VALVE COVER?? Upon further investigation he noticed that the Pro Comp 1.6 rockers showed evidence of contact with the valve covers that MM was running on his engine??
So has anyone else run up on this problem and if so, what did you do to resolve this issue??
 Post Posted: Wed Mar 02, 2011 6:02 pm
YO! the problem is the procomp heads! I checked in w/kevin and he had seen it before, so they are (in) for a trim job on the milling machine. I aint fraid !
R&R Cycle, Performance Parts and Service
for Harley Davidson Motorcycles.
 Post Posted: Wed Mar 02, 2011 10:17 pm
OK so I was right then. The rocker stud is closer to the valve cover gasket surface or visa versa. Wonder WTF they did that? :-k
Ennywhoot, glad you got that resolved.
So when are you going to swap engines? =;
We got the engine back in the Camaro tonight but still have some stuff to put on it before it will run. Probably fire it up Saturday. Got a crack in a header tube again that I've got to weld up before I install it. It's been welded twice in the same place and now it's cracked again?? Oh well.
 Post Posted: Thu Mar 03, 2011 5:30 am
So you have the intake all hogged out to fit your heads then?
 Post Posted: Thu Mar 03, 2011 10:55 am
Somewhat, yes but I did leave some in there for future porting if I choose to go that route. The smallest part of the intake runner is at the head flange though.
