 Post subject: Valve Adjustment??
 Post Posted: Tue Mar 01, 2011 10:54 am
On a cold motor, How much tighter to you set your adjustment???
 Post subject: Re: Valve Adjustment??
 Post Posted: Tue Mar 01, 2011 12:50 pm
.004 is what I do.
 Post Posted: Tue Mar 01, 2011 1:47 pm
.004 will get you close. If by chance it is a tight lash cam you might not go that much, usually those are around .016 to .018 lash. Anything in the .020's should be fine.
 Post Posted: Tue Mar 01, 2011 3:21 pm
I'm assuming cast iron block and aluminum head ..... for my BBC I use 0.006
 Post Posted: Tue Mar 01, 2011 5:57 pm
.004 here on my aluminum head iron block SBC and it comes out right when it's hot.
 Post Posted: Tue Mar 01, 2011 8:29 pm
Mark, cam card says 19/24.......So should I set the exhaust at .020 and the
Intake say .017 ? Then check it after a run...
Yes.....
 Post Posted: Tue Mar 01, 2011 8:51 pm
I'd go .015 and .020 and see how it checks hot, and, you don't necessarily have to make a run to see what "hot" settings are. You can use the fan switch to run the engine temp up around 200/210 degrees and let it run there for a few minutes and you should be in the ball park to check it hot. Might even run it up on the verter a couple of times to put heat in it quicker. And you can do all this at home.
A little on the tight side is better than too loose, IMHO as when it's tight it's just picking up the ramp earlier whereas when it's loose it's late on the ramp and that jars the lifter more.
If memory serves, that 496 of gdmii's was .004 off as well cold to hot. ;-)
 Post Posted: Wed Mar 02, 2011 10:11 pm
.004 has always worked for me.
 Post Posted: Sun Mar 06, 2011 5:24 pm
thats what I go by also....004...
James
79 Z28 496 BBC....
