 Post subject: Piston Ring End Gaps?
 Post Posted: Fri Feb 25, 2011 3:39 pm
Just opened up this Total Seal ring set today and was looking at the instructions on end gaps. They say that top ring is .0045 x bore and second ring is .0035 x bore??? It's my understanding that if the second ring doesn't have a larger end gap than the top ring that pressure building between the top and second ring will "lift" the top ring and cause it not to seal? :-k
The last set of file fit rings I used were gapped at .018 top and .025 second. Anyone have a reason to do any different this time? :-k
 Post Posted: Fri Feb 25, 2011 4:20 pm
I just re-visited this last week and a few professional builders I've spoke to continue with that same approach. 2nd ring gap is larger to help release pressure under 1st ring to aid/help compression ring seal. That's how I just sized mine last week. I'm actually tightening my top a little and opening my second a bit more for this build. This is a BBC build if that matters.
 Post Posted: Sun Feb 27, 2011 11:27 am
I think I'd stay with having the second ring the same or a little wider than the top ring. If they are the same gap cold, I can't see the second not being more than the top one when they are at running temp.
The second is an oil scraper, so on a 4.155" bore, .005" more end gap will result in an additional .000383% more bore circumfrence not scraped by the second ring. (That's if my math is right)
And I'm not sure I'd narrow the gap much more. I think having them butt will cost more power than having a couple more thousanths gap.
Randy
