 Post Posted: Tue Feb 15, 2011 9:00 pm
Need to know how deep an .043 ring land is. I've measured the .062s on my J&Es for my engine but need a dimension for an .043?? :-k
 Post Posted: Wed Feb 16, 2011 2:02 pm
Most piston mfg cut the ring groove .170" radial depth.
 Post Posted: Wed Feb 16, 2011 3:38 pm
Thanks! ;-)
 Post Posted: Wed Feb 16, 2011 7:00 pm
I checked a .043" piston. The ring measured 0.160" and I was surprised to find the groove was much deeper at ~ 3/16" (with ruler) or 0.187". O:) ... They were from a long time ago, but I thought I bought the rings with the pistons from Ross. That's a LOT of back clearance. The 1/16" ring pistons from the 383 engine I'm working on measure .185" and the groove measured the same depth as the .043" piston. With the ring all the way into the groove I can barely feel an edge with my fingernail from the ring to the piston (the ring pushes in slightly deeper than the edge of the piston). That is how I would want the back clearance.
The .170" that jdeleon mentioned would be about right for the rings I have.
 Post Posted: Wed Feb 16, 2011 7:53 pm
My J&E .062 ring groove is .200 deep? The used top ring I have out is .185/.186 and a new top ring is .188 = .012 clearance. Called Kowalsky after I posted this and got some real funky numbers? I think it's some propriety stuff he does to those late model engines he builds. :-k
 Post Posted: Wed Feb 16, 2011 8:30 pm
FYI
The .170" radial depth is what is commonly used today in racing and many pro series piston and ring pkgs. The SAE specs that were the standard for ring thickness for many years is :
Radial thickness= bore"/ 22
It was not uncommon to use backcut rings in std grooves.
 Post Posted: Thu Feb 24, 2011 8:33 am
Not sure if it will help much Ken, but I can measure the lands in my JE's. I'm running 1/16" rings though...........
Mark Goulette
 Post Posted: Thu Feb 24, 2011 8:47 am
Never mind Mark. I already finished it. ;-)
 Post Posted: Thu Feb 24, 2011 9:01 pm
How did gas porting you pistons turn out anyway Ken? How many did you go with,...distances between them?
