 Post Posted: Fri Dec 17, 2010 1:07 am
So i know this may be a loaded question but,
im interested in peoples opinion of what type of HP/rpm range this combo may operate in?
combo is,
410 in LS based engine
4.030" bore
4.00" stroke
14.7 compression
6.125" rod
268-276 @050 692-685"w 1.8 shaft rocker
tight lash CAMMOTION solid roller
245ccLSX TRICK FLOW 13.5 DEGREE heads cnc'd w some hand blending done also- 2.100 hollow stem int valves -1.6 exh valves
both weigh 91-92 grams
flow numbers-int 360cfm-exh 270cfm both at 650" lift
ported super vic intake w modified hp 1000 carb
1-7/8 header to 3.5 in exhaust
IM MAINLY INTERESTED IN WHERE THIS THING MIGHT MAKE POWER TO AS TO SEE IF IT MAY BE OVERCAMMED?
Im hoping for it to peak at 7300-7500 rpm or so
Any guesses /
thanks
ps .heres a vid of the old 23 pump gas setup i ran lasy yr :-$
http://s1219.photobucket.com/albums/dd4 ... r008-1.mp4
 Post Posted: Fri Dec 17, 2010 10:26 am
Somewhere around 750-780, at around 7800 if tuned well.
