Ken0069
Posted: Mon Mar 14, 2011 5:27 pm |
Site Admin |
Beretta wrote: YES, was going to change it when I drained the break in oil out. I also run the oil filter on my Geo for 6,000 miles, which is usually about 2 to 3 years of driving. The filter on the Dodge goes 5k miles and the oil goes 10k miles. As best as I can tell, that filter on the race engine only had 25 miles or so on it? FYI, I put the same oil rings, rod bearings and half the mains back in it that I took out too. Used the same valve springs but did put a new timing chain on it along with two new MLS head gaskets. And get this, I'm putting the same synthetic oil back in it too that had half a season of runs on it! You really don't realize just how cheap I am, do ya!
Beretta
Posted: Mon Mar 14, 2011 6:16 pm |
What did you use for break in oil??? If it has a lot of Molly in it that is what plugged your oil filter....Break it in then get it out and change the filter...
Ken0069
Posted: Mon Mar 14, 2011 6:56 pm |
Site Admin |
Beretta wrote: What did you use for break in oil??? If it has a lot of Molly in it that is what plugged your oil filter....Break it in then get it out and change the filter... 8 quarts of 10W40 Rotilla T and OLD style GM EOS for break in. We're planning to go test this coming weekend.
Slowpoke
Posted: Mon Mar 14, 2011 11:44 pm |
Joined: Wed Oct 24, 2007 6:36 pm Posts: 718 Location: Blanco, Texas
Good Luck, Hope you fly with all four tires on the ground!!!
_________________ Donee
StrokerCamaro
Posted: Tue Mar 15, 2011 4:08 pm |
Joined: Tue Apr 18, 2006 10:44 pm Posts: 1507 Location: Tennessee
Ken, I knew ya was cheap but damn, not that cheap lol
BarryW
Posted: Tue Mar 15, 2011 4:35 pm |
Joined: Mon May 17, 2010 9:34 pm Posts: 115 Location: Georgia
Ken...I guess nobody asks for any of your used stuff ?
Ken0069
Posted: Tue Mar 15, 2011 5:04 pm |
Site Admin |
BarryW wrote: Ken...I guess nobody asks for any of your used stuff ?  Yeah, it broke my heart to have to pull that set of Crower offset roller lifters out and replace them when they only had 300 passes on'em. Probably have the Wife list them on fleabay to see if I can get some of my money back out of'em. Last set of used lifters I sold on fleabay brought $120. Was going to reuse those Cometic head gaskets but the coating was coming off of them and I was a little gun shy of'em because of that. I still have them though and may use them yet!
rick360
Posted: Tue Mar 15, 2011 7:40 pm |
Moderator |
Ken0069 wrote: Yeah, it broke my heart to have to pull that set of Crower offset roller lifters out and replace them when they only had 300 passes on'em. Probably have the Wife list them on fleabay to see if I can get some of my money back out of'em. Last set of used lifters I sold on fleabay brought $120. Sold for $100 to Rick ... That wasn't so hard. I'm cheap too, but even I put new oil in after a rebuild. I just don't rebuild as often as most. On my daily driver (yeah its a beater) I change the oil once a year. That's ~18k miles/yr and no its not synthetic. This is the 2nd car like this (88 chevy 2.5L FI 4cyl) I've had and it doesn't hurt them at all to do that. My last one went 215k (100k was me) and the frame/body rusted off it and the engine/trans was still good. My current one I've had for 4.5yrs and still going strong at 165k. Rick
Ken0069
Posted: Tue Mar 15, 2011 10:09 pm |
Site Admin |
In my defense, that Rotilla T oil that was put in was new.  Just left the old oil filter on it for break in. That synthetic that I ran half the year last year is Mobile 1 V Twin oil that was around $12 a quart if memory serves but it's got the good ZDDP in it is the reason I put that in there. And the cost of 9 quarts of it is the reason I'm going to run it this year also.
inVEGArating
Posted: Wed Mar 16, 2011 7:29 pm |
Joined: Sun Sep 17, 2006 9:52 am Posts: 402 Location: southern,ohio
your not cheap ken...your thrifty!
want-a-be
Posted: Sun Mar 20, 2011 10:28 am |
Ken0069
Posted: Sun Mar 20, 2011 3:36 pm |
Site Admin |
Went to Eastside Speedway today and it was a wasted trip!! ](./images/smilies/eusa_wall.gif) Out of three attempts I never did get down the track!! Good news is after three 8K RPM burn outs the engine is still in one piece with only a slight oil leak in the front this time, which will probably require that the pan come off yet again. Oh well, will give me a reason to look at a bearing or two. Dodge did good too so even though it was a wasted trip, everything came home usable for the next trip. Think I'll go south next time. On another note, don't know if it was just me but this engine sounds much different from what I remember last season?? Seems to like the upper RPM range too?? Can't wait to get on a track that will hook!
BarryW
Posted: Sun Mar 20, 2011 6:46 pm |
Dragsters don't have any problems getting down the track.....
Ken0069
Posted: Sun Mar 20, 2011 7:11 pm |
Site Admin |
BarryW wrote: Dragsters don't have any problems getting down the track.....  You just HAD to throw that in didn't ya!  Thanks for reminding me. Truth is, there was one dragster there today. He tried one pass then loaded up and went home. I wasn't far behind him.
